WD 45 Value
JRT
10-29-2002 20:33:36
Someone has offered me 1800.00 for my WD 45. The tractor was overhauled and painted about 10 years ago but I have never used it since. Also it has power steering and very tight wide front. Is that about its worth or should I hold out for more? Thanks.
KL
10-31-2002 15:15:29
 Re: WD 45 Value in reply to JRT, 10-29-2002 20:33:36
Where are you located, I might be interested.
Ron
10-30-2002 17:12:21
I just purchased a WD 45 for $1975 with a wide front and allis loader no ps . you be the judge.
Jim in Michigan
10-30-2002 15:56:10
if i could get 1500 for mine with the loader and 2 bottom plow it would be sold,,for another 600 I would throw in a WD its plow and the partial loader I have for it too,,,mine isnt power steering though, but it is a wide front...Jim
JRT
10-30-2002 15:16:55
Thanks Guys, You have helped me to decide. I think I will hang on to it for awhile.
Larry
10-30-2002 07:05:06
I would say hold out for atleast $2500. Rough looking WD's with wide fronts that run good routinely sell for $2,000 to $2500 in Central Oklahoma. The extra power of the 45, the factory PS and restoration/rebuild make it worth atleast $2500.
Mark/Ks
10-30-2002 04:49:24
I agree with Bill, Power steering and Wide front bring a premium. My advise is not to take less than $2250. If the restoration still looks nice then $2500 is not out of line..
Bill (MN)
10-30-2002 03:01:17
I'd hold out for AT LEAST $2500 regardless of where your at. Factory power steering is a huge factor as well as a wide front. If the tires are like new and the overhaul was complete that will increase the value a bit more. If your in a situation where you have to liquidate it try listing here or e-bay so it gets some national attention. A lot of folks are looking for a tractor like yours.
Bill
Justin
10-29-2002 20:51:25
Depends on where you are lcoated. Sounds about right for my area possibly a little low but depends on tin and engine etc. Probably will be able to get more if youa re down south or possibly less if you are up north.
Justin
