Can I add a starter to a 1939 B?
Dan
10-29-2002 19:45:33
I have a 1939 B w/crank only for starting, anyway to add electric start? work tractor.... not for shows....
Thanx, Dan
Ron
10-30-2002 09:57:43
 Re: Can I add a starter to a 1939 B? in reply to Dan , 10-29-2002 19:45:33
Dan, I assume your "B" is getting "cranky" to start (a little play on words ?). I too have a '39 "B" (mag ignition and crank start). It had been getting kind of a pain to get started lately. About a month ago, I took off the magneto (original FMJ type) and discovered problems with the impulse spring assembly (part of it was missing, must have happened before I bought it 25 years ago). Anyway, on the advice of this board I wound up with a newer FMX magneto. Presto, instead of breaking my 50 year old back cranking the thing countless times, it would fire up on the second 1/4 turn crank (like they did when they were new). Then (again on the advice of this board) I added AutoLite 295 spark plugs (instead of those "crappy" Champion J-8's), and my ol' Allis thinks she died and went to heaven (as well as my back). Truly an amazing difference !
Butch(OH)
10-30-2002 04:11:28
To convert you will need to find a torque tube for electric start and of course a starter, charging system and wiring. About any tractor salvage yard will have a B or two or try Roger Vancamp in Fort Wayne IN.
Dan
10-30-2002 06:47:56
 Re: Re: Can I add a starter to a 1939 B? in reply to Butch(OH), 10-30-2002 04:11:28
Can anyone post a picture of the torque tube,
Is that like the whole frame between the engine and the shifter area?
Butch (OH)
10-30-2002 07:14:14
 Re: Re: Re: Can I add a starter to a 1939 B? in reply to Dan , 10-30-2002 06:47:56
Yep that would be it, one for a starter will have a hole on the right side.
About forgot,
10-30-2002 04:12:25
You will also need a ring gear for the flywheel
Don LC
10-30-2002 07:14:24
 Re: Re: Re: Can I add a starter to a 1939 B? in reply to About forgot,, 10-30-2002 04:12:25
Your best bet is buy another tractor and then sell yours.....
aaron
10-29-2002 20:36:41
Here is a non technical answer. Hand cranking is the easier way on such a small motor. Why give it up? I have a 1938 farmall 20 and it starts way more reliable than the other M's and such because there is no battery to go dead.
Justin
10-29-2002 20:54:30
 Re: Re: Can I add a starter to a 1939 B? in reply to aaron, 10-29-2002 20:36:41
I agree! My B, starts great by hand and gives me a hard itme if I use the starter.
Justin
