AC 160 info
Kent
10-26-2002 13:50:58
I am going to look at a 160 diesel. I have never seen a 160 and need help on what to look for on this machine. I know the tractor has new injectors and rebuilt pump. What years did they make these and any idea where to find serial# on tractor?? I can't find a serial# reference for the 160 either. If someone could shed some light on specs(hp,etc) also would be great. Thanks Kent
Tom
10-27-2002 16:58:46
 Re: AC 160 info in reply to Kent, 10-26-2002 13:50:58
Did you try www.tractortips.com
Kent
10-26-2002 20:38:34
David, Thanks for the help, I didn't realize there was a one sixty and a 160. If you come up with anything else or any suggestions they would be appreciated. Thanks Kent
david l wilson
10-26-2002 16:39:18
the one sixty was built on 69-71, the 160 was in72-73.this tractor was built by reault of france and modified to a-c specs. the engine is a perkins 3.152 3cyl. 152 c.i.diesel that developed 40.36 pto hp at 2250 rpm. the ser. # is located on a plate ahead of the fuel tank. my books show no info on years by ser.#. that is all the info i could find in my allis books hope it helps. david l wilson
