WD Engine Upgrade
Bruce
10-25-2002 22:02:00
I bought a WD45 or what I thought was one with s/n WD173984 and found out yesterday while taking it down for rebuild that the stroke is only 4". The engine s/n is WD305828PA. Don't know what happened or when but I would like the engine to perform more like an Allis 175 than a WD.
What is the best approach? Find a 45 crank, install 4-1/8 overstandard pistons and sleeves, change cam, etc. Or find another engine.
Any help is appreciated.
Also, where can I find the cam profile specs for the 45, D17 and 175 or who is good at building cams for this engine?. I understand that this is one of the things Allis changed with later models to increase the performance of this engine. I want a strong usable WD45, not looking for a setup which is only useful on the pulling track. Thanks!
Tom
10-26-2002 19:00:54
 Re: WD Engine Upgrade in reply to Bruce, 10-25-2002 22:02:00
45s are strong and useable, crank and pistons from a 45 and maybe the tall head should make you a 45.
Tom W
10-26-2002 20:06:00
 Re: Re: WD Engine Upgrade in reply to Tom, 10-26-2002 19:00:54
What is the difference between a WD short head and a WD-45 tall head? Are the push rods the same length?
Brian G. NY
10-27-2002 06:21:08
 Re: Re: Re: WD Engine Upgrade in reply to Tom W, 10-26-2002 20:06:00
The tall head breathes better and the spark plug placement is better; more toward the center of the cylinder. The tall head has short "rockers" and the short head has tall "rockers". I believe the pushrods are the same length for both; at least the parts manual lists only one number for the pushrods for both the WD & WD-45.
Brian G. NY
10-27-2002 06:36:46
 Re: Re: Re: Re: WD Engine Upgrade in reply to Brian G. NY, 10-27-2002 06:21:08
BTW, the tall head was introduced on the WD with "engine" #WD289001 some time in '50 or '51. I have a '50 with a short head and a '51 with the tall head. I think there may have been some further improvements to the tall head when the WD-45 was introduced. I have a couple of WD-45s, but I never compared their heads with the one on my '51 WD to confirm that.
Tom W - WA
10-27-2002 19:17:44
 Re: Re: Re: Re: Re: WD Engine Upgrade in reply to Brian G. NY, 10-27-2002 06:36:46
Brian, thanks for the information on the heads. I am putting togeather a WD with a 45 crank, WD pistons and will go with a 45 head with some over size chev. valves installed. Hoping for 8.5=10 compression on a basic low cost home built pulling tractor.
