Wd front pedestal
dave
10-25-2002 15:04:20
I think I have a bearing dry in the front pedestal. Am I correct by presuming the fitting on the very front is for gear oil and not grease? or was the previous owner correct in pumping it full. I have spent to much time looking in the manual and can't find the answer.
Brian G. NY
10-26-2002 08:35:30
 Re: wd front pedestal in reply to dave, 10-25-2002 15:04:20
The grease fitting is for lubricating the steering spindle shaft and lower spindle bearing. Use chassis grease here. To lubricate the worm and sector gears, remove the top cover and use 140 gear lube so that 1/3 of worm gear is submerged. In my case, both the seals at the top and bottom of the pedestal leak and the 140 gear oil eventually winds up on the ground. To solve that problem, I mix chassis grease with the gear lube until I get a consistancy that is less prone to leaking down past the worn top seal.
dave
10-26-2002 08:58:26
 Re: Re: wd front pedestal in reply to Brian G. NY, 10-26-2002 08:35:30
Thanks Brian I'll give it a try.
