What causes Flames to shoot out the Exhaust Stack?
John
10-24-2002 20:13:04
Is the answer "timing"?
Thanks
Tim Sprowl
09-24-2004 07:36:24
 Re: What causes Flames to shoot out the Exhaust St in reply to John, 10-24-2002 20:13:04
Well now, I have kohler engine, a small one of cource. I have flames that come out of it and it is caused from the valves. In lifes lessons I find the basic principle is the best teacher. At any rate this was a free opion.
Puller504
11-03-2002 16:55:38
 Re: What causes Flames to shoot out the Exhaust Stack? in reply to John, 10-24-2002 20:13:04
Hi, John. Not real sure what causes the flames but my friend and former owner of my Oliver 1600 gas tractor was smiling wide at the last pull. I weighted down the 1600 on a bet and pulled it in the 9000# stock class. (it's stock) Blue flames 6 inches out the 4 inch chrome stack as it clawed down to 2-3 feet from the JD 4020 diesels! My friends on the 4020's stopped laughing as I downshifted the Hydra Power and nearly beat them! Can't wait for spring. Don
Dave k
10-25-2002 17:03:27
Our WD's, even when new from the dealers, would always put out a flame under heavy load. Can't see it much in daylight but plowing at night the whole manifold will be cherry red with a nice blue flame at the stack. Pretty sight to go along with the working sound of the engine. Never caused any problems with our tractors.
Dave
John C
10-25-2002 07:44:37
I checked out the timing today. It was out. I ended up turning the distributor 1/2 inch counter clockwise to get it in time using a timing light.
I'm no mechanic but to me seeing flames coming out of the muffler when there shouldn't be any is a bad thing. I didn't want to take the chance of burning the valves. Now with the timing set correctly, and the electronic ignition the old d-17 runs better then it ever did. Later
John
Mark/Ks
10-25-2002 04:33:04
On my project I started last March, My WD-45 was shooting flames also. Mine was shooting flames at idle and were mostly yellow in color. This turned out to be timing. I advanced it, and now sounds and runs good. If the flame is blue and under load, then that is normal.. I still get an ocassional flame when operating at high idle, then pop the throttle closed.
Steve in N.J.
10-24-2002 22:29:29
John,
Timing can have an effect on what comes out the exhaust pipe, or in this case stack, but usually it's the fuel mixture that plays a big part of the "fireworks" display. Lean mixes tend to heat up a manifold, stack, or header to where it would glow. Rich mixes add the "Burzamatic" effect. Depending on how much load the engine is under, and the fuel she's quenchin', unburned fuel coming out a super hot exhaust manifold or header can be an awesome site. I ran a Pro Dragster many years ago, and depending on how much fuel we put to her, at the 1000 foot mark all 8 candles were lit in the evening hours! Steve B.
Sid
10-24-2002 20:40:02
Don't think so. At night my tractor and a lot of other gas rigs will belch fire at night when shut down the throttle or when the govenor opens up on a pull. I think this is just hot gasses that are their even in the day time.
Bill
10-24-2002 20:16:46
I have a WD45 that will put a flame out when you crack the throttle to idle, and a D19D that will put a foot of fire out when the going gets tough.
