Re: WC WD differences
Brian Watson
03-04-1999 08:43:36
The easiest way to tell is does it have hand brakes? if so it is a wc. All wd's have foot brakes. On a wc if you look on the rearend there will be a place on it near the center as you look at it from the rear that has numbers stamped in it. Look cloosely, if the rear is pressed steel and not cast iron as most are it is a war production era machine. The transmissions are very different. A wd will have a short straight shifter or a short curved shifter. A wc will have a long curved one with a reverse lockout on the lever.
Hope this helps Brian
