REMOVING D-17 ENGINE
CJW
10-23-2002 09:33:56
I AM CUURENTLY REBUILDING A '62 D-17. I HAVE REMOVED ALL THE BOLTS FROM THE BELL HOUSING, BUT CANNOT GET THE ENGINE REMOVED. IS THERE SOMETHING THAT WOULD CAUSE THE ENGINE TO HANG UP?
geb
10-24-2002 06:20:06
 Re: REMOVING D-17 ENGINE in reply to CJW, 10-23-2002 09:33:56
Make SURE you have all the bolts out and then you might have to drive a screw drive in and pry it apart. Again make SURE all the bolts are out!!
Tom
10-23-2002 18:00:26
Is there a sheetmetal plate on the lower half of the bell housing that covers the bottom of the flywheel. Or did you remove it?
