Power steering leak
KEN C.
10-22-2002 18:38:59
The power steering oil leaks out between the front wheels.Is this something that is easy to fix by removing the front end and replacing a seal, or is it more involved. By the way it is a D 17 tri cycle front end. Any help is appreciated, ken.
david l wilson
10-22-2002 21:00:44
 Re: power steering leak in reply to KEN C., 10-22-2002 18:38:59
sounds like a seal to me. drop the front end down by removing the bolts [ 6 i think ] in the top flange of the front pedistal [ make sure the wheels are streight before you start ]. then drop the mud shield down be sure to leave the bolts not going through the shield in the housing to hold the seal and steer gear housing together.CAREFULLY take the rest of the bolts out, this will loosen the steering shaft and may let it fall. watch close to be sure to get all shims and steering shaft back in the same place [ if you don't it will turn tighter one way or the other. now you can replace the seal and put it back together. if you need any help let me know or pick up an I&T manual . hope this helps. david l wilson
KEN C.
10-23-2002 17:37:58
 Re: Re: power steering leak in reply to david l wilson, 10-22-2002 21:00:44
Thanks for the info, I'll give it a try.ken.
david l wilson
10-23-2002 21:02:24
 Re: Re: Re: power steering leak in reply to KEN C., 10-23-2002 17:37:58
like i said ken if you need anything else let me know. good luck and happy wrenching. david
