Oils-wd45
chucky
10-19-2002 19:58:30
what weight oil and how many qts.do i need to change oil in my wd45 for the winter.we will be using it to push snow up here in Minn. thanks for any replys. chucky
DanD.
10-20-2002 11:27:14
 Re: oils-wd45 in reply to chucky, 10-19-2002 19:58:30
WD-45 will take 7 quarts of oil with oil filter change. Use 10W oil or 10W-30 for winter.
Doug in OR
10-20-2002 10:30:48
I don't remember exactly how much oil that tractor takes. I believe it is in the 4 to 5 quart range. AC originally specified SAE 10 oil for winter use in the WD. I'm sure you can use SAE 10W-30 or SAE 10W-40 during winter or summer, with todays improved oils.
Bryan Smith
10-21-2002 06:20:16
 Re: Re: oils-wd45 in reply to Doug in OR, 10-20-2002 10:30:48
I have the specs up on the web from the original WD45 manual on my page (link below) fyi. Check under oil type recommendations .....
