AC 6070 clutch adjustment
steevereno
10-19-2002 13:07:08
Need to adjust the pto and traction disc release fingers on the pressure plate. I&T manual says to use ACTP-3082 (special tool) I don't have this tool and was wondering if anyone knows the distance from the pto clutch hub to the top of the fingers (pto and traction). I would like to make the tool if I knew the tools measurements.
Kraig
11-04-2003 22:46:19
 Re: AC 6070 clutch adjustment in reply to steevereno, 10-19-2002 13:07:08
You can take it to a dealer and they should have a plate they bolt the clutch to and set the fingers, or you can take the flywheel off and have them set it up on the bench for u and u just take it home and slap it on.
greg
10-27-2002 16:20:03
I have been in the same shoes you are in right now.... I have the information around here somewhere, needed it about 3 years ago, if I can find it I will forward the dimensions to you, be patient, or find a dealer who has the manual for it. These things are a bear. I had a major manufacturing plant make a tool for 6060 6070 and 6080 models to make clutch setup at installation easy. (No screwing around splitting the tractor 6 times to get finger height correct) Good luck with this, and I hope someone else out there has this info and can respond faster than I think I will.
