Electronic Ignition?
John
10-16-2002 03:53:19
Has anyone tried to put an electronic ignition into a older allis chalmers tractor? Here is a website of what I am talking about Link
I>Link have a 1958 D-17 that I am thinking about doing that to. I am woundering if anyone has tried this and what are your thoughts are on it? Any +/-'s?
Thanks John
Nellie
10-19-2002 04:20:02
 Re: Electronic Ignition? in reply to John , 10-16-2002 03:53:19
I did my 59 D17 3 yrs ago. It was easy to do and Genesee is a great supplier. I agree with Aaron put the electronic ignition in and forgetabout those points. Wait to you see the difference in spark.
RMD
10-17-2002 07:14:27
Last time I checked, the electronic ignition kits required 12 volt negative ground. So you would also have to convert the tractor electrical system.
Bob Semrau
10-17-2002 14:49:59
 Re: Re: Electronic Ignition? in reply to RMD, 10-17-2002 07:14:27
They also have 6V positive ground models now - I have one on my Ford Jubilee.
Aaron Meek
10-16-2002 06:25:00
I also install one of the kits from Genesee in my '63 D15. Works like a charm. And at the rate I was killing points it will pay for itself rather quickly. ( tractor sits for long periods, the points had a nasty habit of coroding on me. There is nothing more anoying than getting some time to do some work, and the tractor is running like absolute &^*&^#$ due to bad points. ) The D15 now starts on the second revolution every time.
arm
Dave Grubb
10-16-2002 05:52:35
I installed a kit from Genesee Products in about 20 minutes. I couldn't be more pleased with the system. The dwell and therefore the timing stay constant with this system and I don't have any condensor break downs. I know the ignition on the AC's are pretty reliable and simple, but I do like the solid state kit.
