Re: Allis Chalmers B Engine Block
John W.
10-16-2002 00:58:08
Randy; Keeping in mind we are now 50 years past the time the last of the B's were built, Blocks are becoming hard items to put one's hands on. So long as yours has no gaping holes in it, from a thrown rod or freezing solid, it most likely can be repaired. Cracks are not a huge problem to fix, they can be brazed or welded. However, if the block is indeed damaged beyond repair, there are several tractor salvage yards from which you can get a block or,more likely, a complete engine. Many of the salvage operators are unwilling to stripe an engine to sell a block. I have six tractors with repaired blocks that run perfectly. The worst was cracked in the webs between the cyl's. Unless the block has pieces broken out and missing it can, in all likelyhood, be repaired and reused. Good Luck.
