Allis chalmers CA Surges And Then Dies
Tony
10-11-2002 18:12:32
The tractor will start fine run for a few minutes when you speed up the thorttle to fast or back off to fast it will start to surge real bad and then die and the tractor could be running at a certin speed and out of no where it will surge then die. "Any ideals"
Bob, Ohio
10-15-2002 06:49:26
 Re: Allis chalmers CA Surges And Then Dies in reply to Tony, 10-11-2002 18:12:32
Check the fitting that the fuel bowl screws into. Unscrew the fuel bowl and then unscrew the fitting from the tank. Mine was totaly plugged with rust. Ran fine after I cleaned it out.
Don LC
10-14-2002 07:43:05
Tony,
It sounds like the engine is starving for gas...check "every" place in the gas system for blockage..... .
