Allis Chalmers B Rear Wheel
Kevin
02-28-1999 16:27:02
I recently purchased an Allis B that I plan to use for lawn mowing. One rear wheel (left) is loose on the axle and was wondering if there are any tricks involved in tightening it.
Dean
03-09-1999 14:56:22
 Re: Allis Chalmers B Rear Wheel in reply to Kevin, 02-28-1999 16:27:02
Grind off the back of the wheel so it can slide on farther before it bottoms out. You can also try thin shims and/or epoxy in the splines. Put the shims in so they aren't under load in the forward direction.
Rollie
03-04-1999 18:27:31
I Have Noticed That The Early Tractors Have A Tapered Course Splined Shaft And As They Wear There Is A Noticible Amount Of Play,What I Have Done To Correct This Is To Add Oversize Shims Behind The Large Nut And Lock Washer
