What was It?
steve
10-07-2002 23:56:08
Im not very familiar with AC tractors, but I saw a nice find the other day. I pulled into a gas station and there was an old AC tricycle on a trailer there. It had mid and rear cultivators and a big spring under the rear end. It also had power shift rear rims. I spoke to the man and he didnt know what it was. He and his boss were clearing some land for a guy, and the owner said just to take it!. It still had a few small branches hung up on it, along with three flat tires. Was it a C or a CA? In hindsite I probably should have offered him $200 for it. Orange would probably look good beside my old red tractor.
Tom
10-08-2002 17:44:49
 Re: What was It? in reply to steve, 10-07-2002 23:56:08
I would certainly try and get it. Maybe for less if the engine doesn't turn though. Check the boot on the shift lever. If it is missing or rotten there could be water in the transmission which could have done damage to it. Especially if it freezes. Don't knowif it gets that cold where you are.
steve
10-08-2002 15:57:56
if it had c-channel frame rails down the side of the motor to the radiator it was a WD-WD45. if there were no rails, just the motor bolted to the clutch-torque tube housing, then it was a CA.
Brian G. NY
10-09-2002 16:30:57
 Re: Re: What was It? in reply to steve, 10-08-2002 15:57:56
That's the best indicator; so obvious, too.
JMS/MN
10-08-2002 00:14:23
CA and WD had power-shift rear wheels, but the spring under the rear end just confuses me! Unless you mean a coil spring (horizontal) above the front end of the drawbar- that's on a WD, and is part of the Traction Booster, weight transfer system.
Brian G. NY
10-08-2002 04:58:46
 Re: Re: What was It? in reply to JMS/MN, 10-08-2002 00:14:23
Probably a CA since the drawbar spring is more noticable and further back than on the WD. Another feature that "sticks-out" is the high location of the steering drag link; above the gear box. CA has 24" tires vs 28" for WD & WD-45.
JMS/MN
10-08-2002 00:15:37
Oops- CA also had the Traction Booster system!
