Ac 918 backhoe?
Larry
10-05-2002 07:58:56
I am considering buying a backhoe/loader that needs transmisson parts. Where is the ID tag? Is there any other means to positively indentify what model it is?
Unimog
10-05-2002 19:06:00
 Re: ac 918 backhoe? in reply to Larry, 10-05-2002 07:58:56
I have limited knowledge of the 918. It was made
from the late 60s to 1975. Only around 245 units
were produced. It's a large machine tipping the
scale at 18650# and has a 1 1/2 yard front bucket.
AC did not make too many different loader/bachhoe
models so it shouldn't be hard to ID. It uses a
model 2800 diesel engine that produces 85hp. It
is a low production model so parts might be a bit
hard to find, but anything can be made if need be.
Larry
10-06-2002 20:17:41
 Re: Re: ac 918 backhoe? in reply to Unimog, 10-05-2002 19:06:00
Thanks for the info! The basic repair issue is broken teeth on transmisson gears, which should be less costly used vs. new, if available. I can't seem to locate the model tag where it is supposed to be-left loader frame. Engine tag no problem-2800 series engine. Are there any features on the 918 not used on any of the several other models of that era? Such as the three glass panes per cab side?
Thank you
