WD 45 steering shaft
ACSam
10-03-2002 17:13:50
I just bought a WD 45 wide front. The steering shaft has a device that doesn't look familiar to me. About where the belt pully should be, the steering shaft has been cut and what might be a charlyn hydraulic motor has been installed. There are no hydraulic lines hooked up to it, but there are places where they should be hooked up. What do I have?
Tom
10-03-2002 18:10:02
 Re: WD 45 steering shaft in reply to ACSam, 10-03-2002 17:13:50
Power steering. Sounds like it isn't connected. See manual which you should be getting since you already have the tractor.
Mark/Ks
10-04-2002 03:34:08
 Re: Re: WD 45 steering shaft in reply to Tom, 10-03-2002 18:10:02
Tom is correct.. PS on the WD-45 also helps with the value..
