Snow Removal
TomZ
10-02-2002 14:56:56
I was looking to purchase an AC for snow removal on a good size driveway. Does anyone have any input as for a standard front mounted truck plow vs a grading blade. I have seen regular snowplow blades mounted on the front. Is there a kit or plans for this or are these custom? I was undecided on size (B, C, WC, WD)because I was not sure what would suit my needs best. Thanks
Dan
10-05-2002 06:08:16
 Re: Snow Removal in reply to TomZ, 10-02-2002 14:56:56
my driveway is 1/4 mi long in northern wi, so i needed a good way to plow snow, mounted a plow at an angle attached to the arms of a loader on a D12, works great.
WILD CHILD
10-06-2002 06:56:22
 Re: Re: Snow Removal in reply to Dan, 10-05-2002 06:08:16
I had a WD-45 with an after market 3pt hitch and a 7-1/2' snowblower on it worked great!! you could always use the hand clutch in heavy snow.
Doug in OR
10-02-2002 20:02:43
How much snow are you talking about? Six inches or less on average, I'd get an Allis with a 3 pt hitch - and then find a rear blade. Heavier snow? I'd consider a tractor with 30+ hp and a front end blade/loader combination.
Tom1
10-02-2002 17:27:05
A B or C with weight or loaded tires and chains will push quite a pile of snow, but the live hydraulics of a WD, CA, or 45 would be nice. You do get used to dealing with the hydraulics when they are not live though. Have a B with a snowplow and although we haven't had much snow in recent years, I have seen it push quite a good pile. Depends on how much you get and how fast you want to remove it I guess. Chains and some sort of weight will benefit any tractor though for snowplowing.
steve
10-02-2002 18:13:27
 Re: Re: Snow Removal in reply to Tom1, 10-02-2002 17:27:05
I have a B with a rear dirt blade. good dual purpose tractor, but always looking behind you. Have seen a WD45 with a loader frame, remove the bucket in the winter and install a V or flat blade for pushing snow. Use the loader in summer for other work. Sounds like a good "dual purpose" machine also.
Lon
10-04-2002 16:58:27
 Re: Re: Re: Snow Removal in reply to steve, 10-02-2002 18:13:27
I've got a 43 model C with a home made front blade that has moved more than one pile of dirt.
Snow is nothing for it .
steve
10-04-2002 17:33:19
 Re: Re: Re: Re: Snow Removal in reply to Lon, 10-04-2002 16:58:27
like to see a picture of it if you have one. does it connect to the front end, or have bracing back to the bell housing or all the way back to the axle? I got two or three ideas in my head, like to see one in actual use.
Tom Z
10-06-2002 17:25:32
 Re: Re: Re: Re: Re: Snow Removal in reply to steve, 10-04-2002 17:33:19
Steve,
Actually seen a few, but one was on a c in the photo ad section here posted on 9/28/02. He E-mailed me back and said the person he bought it from had made the hook up himself and that he perferred it better than a pull behind style.
Lon
10-04-2002 16:57:34
