Re: CA and B compatibility
steve
10-01-2002 16:06:13
the B and CA used the same motor. even if you have the oldest BE motor in the B, they will still interchange. The CA has a 4 speed transmission, but same bolt pattern. they have the same bevel gear box. axles on the B are narrower, but same bolt pattern. I saw a CE motor with a 4 speed (CA) transmission, with two narrow rear axle drop boxes (from a B) last summer. nice looking tractor. FOr you info the CA motor and CE used in the C and B are different internal and you cannot interchange some internal parts, but as a complete unit, no problem.
