Wd45 locked in gear
peter
09-27-2002 15:37:37
was using my wd and went to shift gears and it was hard the next time i put in gear now it wont come out of gear thanks in advance ps when i tryed shift lever came loose
bung
09-28-2002 05:30:05
 Re: wd45 locked in gear in reply to peter, 09-27-2002 15:37:37
Hey same thing happen to me, make sure you don't break your shifter off, the clutch was the problem with mine.
Tom
09-27-2002 18:07:51
Take out shifter, snap ring under boot, don't loose key on side that keeps shiftlever from twisting. Line up rails with long screwdriver and flashlight. Put shift lever back in. Be carefull shifting. When you have time take off top of transmission and replace worn parts. Or build up end of shiftlever with weld maybe.
