G -- HOW DOES HYDRAULIC LIFT WORK ?
Don LC
09-27-2002 07:50:59
I got my '49 "G" running,but can't get the hydraulic lift to work !....It must be simple..... ..operating instructions are not in the manual....I guess it could be broken....I have worked the handle up and down ,no movemen't .....can you help ? Thank you....
Patrick
09-28-2002 18:12:55
 Re: G -- HOW DOES HYDRAULIC LIFT WORK ? in reply to Don LC, 09-27-2002 07:50:59
Don, I think you have a major problem. The belt pulley puts the power to the hydraulic system. No belt pulley, no hydraulics. Are you sure that you have no pulley or PTO? Is there a big plate bolted over where the pulley gears are located?
Don LC
09-29-2002 06:00:17
 Re: Re: G -- HOW DOES HYDRAULIC LIFT WORK ? in reply to Patrick, 09-28-2002 18:12:55
Yes a plate bolted where the pully would go....
Patrick
09-30-2002 04:41:34
 Re: Re: Re: G -- HOW DOES HYDRAULIC LIFT WORK ? in reply to Don LC, 09-29-2002 06:00:17
Maybe you could find a pulley somewhere. It should not be too expensive as I imagine most Gs already have a pulley. Maybe you could find one at a salvage yard.
Harold
09-27-2002 09:43:02
On drivers left side at belt pully , there a lever thah must be engaged and clitch out for hyd. to work.. HT..AKA orangetractor1
Don LC
09-27-2002 12:01:12
 Re: Re: G -- HOW DOES HYDRAULIC LIFT WORK ? in reply to Harold, 09-27-2002 09:43:02
My tractor is not equiped with a belt pulley ....
