Weight of an AC C
Mike
09-24-2002 17:51:32
Hello,
My manual states that an AC C weighs 2200 lbs. Later in the manual, it also says that the tractor comes with the tires 3/4 full of a 15% calcium chloride solution. Anyone know if the 2200 lb weight includes the weight added from the solution? If so, anyone know the weight contribution (or the density) from the solution. Thanks in advance.
Mike
bleeding orange
09-26-2002 12:38:53
 Re: Weight of an AC C in reply to Mike, 09-24-2002 17:51:32
The weight of your C at 2200 lbs has got to be dry weight At our local pulls a C will be around 2800 lbs.
steve
09-24-2002 19:43:07
should be able to get about 15 gallons in each wheel at 10 pounds (or better) per gallon. So at least 300 pounds could be added to the rear tires. IF you cram it in you can get a little more gallons.
