Hand Crank for a little C
Dave of Southwe
09-24-2002 10:38:07
Anyone out there have-for-sale/know-the-where-abouts, of a handcrank for a model C? Sure love to get my hands on one. Thanks.
Dave
Jim T
09-26-2002 17:42:16
 Re: Hand Crank for a little C in reply to Dave of Southwest Michigan, 09-24-2002 10:38:07
Dave, I had just the same problem of no crank to work on a friend's C till I called the local A-C collector and he told me to use the one out of my Oliver 70. It worked! Since then I've kept a lookout and believe one from a IH A or B would also work. Good luck, hope this helps. Jim
dave of southwest michigan
09-27-2002 04:47:39
 Re: Re: Hand Crank for a little C in reply to Jim T, 09-26-2002 17:42:16
hey jim..... ..thanks for the response. hadn't seen it till just this morning. i'll keep a look-out.
hope your day is a good one.
dave
Bob
09-25-2002 19:35:07
Hey Dave,
No long ago I lost the hand crank to my Model C, so I got a 3/4" rod about 2-1/2' long, torch bent it in the shape of a hand crank, drilled a 1/4" hole about 1/2" from the end and tack-welded a 1/4" bolt and cut it down to the size of the pin. It has been working as a homemade crank ever since.
Hope this helps.
P.S. Now if I fond my oroginal one, I'll consider selling it to you. How about that?
Bob in NW Ohio
