1949 Model C spark plugs
Terry
09-24-2002 09:54:18
I am helping my dad restore his '49 model C and
was tring to find out what type of spark plugs to install along with the gap settings. I appreciate any suggestions.
Thanks!
Bryan Smith
09-27-2002 06:26:51
 Re: 1949 Model C spark plugs in reply to Terry, 09-24-2002 09:54:18
The last time we hashed this out we came up with using Autolite 295 spark plugs for magneto systems and Autolite 303 spark plugs for distributor systems. Yep, I've used Champions and AC's over the years, but the Autolite runs better by far.
Bob
09-25-2002 19:48:03
Hey Terry,
You would be best off following the advice of these fellas who have given you names of plugs and their numbers and gaps as opposed to the fella who suggested that you refer to the OPERATORS MANUAL for your info. You see the way I look at it would be that if you had the OPERATORS MANUAL at hand, you probably would never have asked the question in the first place.
Good Luck buddy.
Will-Texas
09-25-2002 16:21:52
My manual shows Autolite AN7, AC 45 or J8 Champion. Fot a hotter plug, AN11, AC47, J11 Gap is .032-.035
DanD.
09-26-2002 01:58:39
 Re: Re: 1949 Model C spark plugs in reply to Will-Texas, 09-25-2002 16:21:52
The Autolite AN7 number is not used any more. The current Autolite # is 295 which is a non resistor type plug. AC 45's are no longer available. You have to get R45 which is a resistor type plug. A few years ago, the AC plugs started being made in Mexico and I don't feel last as long any more. The Autolites are USA made. The Champions never have worked well for me.
DanD.
09-24-2002 11:30:12
Go get Autolite #295 spark plugs. The gap is about .030.
JMS/MN
09-24-2002 10:30:15
That info, plus much more, is in the OPERATOR'S manual.
uncle bingo
09-24-2002 22:14:15
 Re: Re: 1949 Model C spark plugs in reply to JMS/MN, 09-24-2002 10:30:15
use champion j8c plugs at.025gap
CHALMERS BOB
09-27-2002 20:35:01
 Re: Re: Re: 1949 Model C spark plugs in reply to uncle bingo, 09-24-2002 22:14:15
I PREFER CHAMPION J11 PLUGS IF THE TRACTOR SEES ONLY SLIGHT USE. THIS IS A HOTTER PLUG AND WILL BURN CLEANER. BOOK SAYS .035 FOR BE ENGINE AND .032 FOR CE ENGINE.
