B riveted front wheel
D13
09-24-2002 04:06:47
Picked up a 39 B for $100. In the parts pile was 1 front wheel riveted to the hub. Wasn't this from 1937/8, with the bolt on wheels from 39 up? I'm thinking that I should sell it to someone who needs it - any guess as to value?
BTW this tractor is complete except carb, tank band, and seat. Hood is folded in half - will probably be a donor for the front lower bolt ears that are torn up on my "good" machine. Rear tires hold air, fronts are junk. Came with the above wheel, front pedestal and steering from a C, and a few other parts. Motor is totally set up but is a BE code - my other 39 has a CR (CE replacement) in it (or I should say my 1945 has a 1939 trans in it). Now I've got enough "good" parts for 2!
Butch(OH)
09-24-2002 06:37:17
 Re: B riveted front wheel in reply to D13, 09-24-2002 04:06:47
The 37s had a wheel all thier own. There was a little overlap in years vs styles but in general the 1938s had a cast iron center and the rim attached with 4 clamp bolts. 1939s has the riveted rims you have. Everthing 1940 on up bolted on with 5 bolts. The riveted wheel would have value to somebody that wanted to keep his 39 correct, if in good shape maybe $50. There is lots of them around.
