Pitman arm bearing
Ron
09-22-2002 16:14:55
Where can I find a pitman arm bearing and bearing housing? I think I have an AC #3 sickle bar mower. It is rear mounted, has a tail wheel, 6' bar, hooks up to the draw bar which I replaced with two point hitch pins and has a hydraulic cylinder to lift the cutter bar. There are no names or numbers anywhere on it. Can provide photos.
Ken/Wa
09-22-2002 20:06:57
 Re: Pitman arm bearing in reply to Ron , 09-22-2002 16:14:55
Try Sandy Lake Equipment. If they do not have it , they can tell you if a dealer does. They recently put me in touch with Tom & Ron in Nicmuth Wi, and I found some new old stock at very reasonable price. 715 678 2271
acd17toy
09-22-2002 19:04:58
take your old bearings out and go to your local auto or bearing store, there should be numbers on the bearings and the brand name also. with those numbers they should be able to supply you with new parts. also try the local Agco dealer. As for the housing go to the local tractor salvage yard. are you postive that the mower is a AC? other companys made semi mount mowers also.
