B motor same as power unit
rob
09-20-2002 15:51:43
i have a combine motor wanting to know if it will fit into a b i have with a thrown rod
Butch (OH)
09-21-2002 14:23:58
 Re: B motor same as power unit in reply to rob , 09-20-2002 15:51:43
I need the mounting brackets to install a B-125 power unit on a #66 combine.
Bus Driver
09-20-2002 17:21:02
I have seen some of the combine engines that have no bolt bosses for mounting a generator. They had only a magneto. Some fabrication probably would enable mounting of a generator. But the engine should work fine in other respects.
Eldon
09-20-2002 20:14:07
 Re: Re: B motor same as power unit in reply to Bus Driver, 09-20-2002 17:21:02
I bought a C with a combine power unit motor in it.....no generator on it, either. I never checked for bosses, but that might be why. Does anyone need a clutch/pto housing for a power unit?
