Combine wheels on WD?
Shane
09-20-2002 15:07:45
Which sizes and what brand of combine wheels will fit on a WD. I am looking to replace rear wheels for a reasonable price and combine wheels are a dime a dozen around here.
Brad Gyde
09-29-2002 18:52:44
 Re: Combine wheels on WD? in reply to Shane, 09-20-2002 15:07:45
Just about any 8 bolt combine wheels should work.. I would stay with the power slides myself, but.... I have saw a d-17 with narrow front and combine wheels (and from my research, neither were stock, as all literature I read shows that all d 17's had wide front and power slides)
Joe
09-22-2002 04:04:45
I believe that wheels off a JD 40 or 45 combine will bolt right on to a WD45 or D17.
JMS/MN
09-22-2002 11:33:15
 Re: Re: Combine wheels on WD? in reply to Joe, 09-22-2002 04:04:45
Yup- I have a set from 45, same bolt pattern, but the wheels are 26 inch diameter. It works, but why mess up a nice tractor with wrong parts? I just kept the wheels in case I wanted to put front duals on my MFWD 4450.
JMS/MN
09-21-2002 12:10:12
Why switch from power-shift wheels? Most combine wheels are 26" diameter, WD had 11,12, by 28. Why go to a dish wheel? If you really need to, you can determine what will fit by using a tape measure.
Steve
09-20-2002 20:48:12
Some older IH combines had 8 bolt hubs and some New Idea pickers had them.(26") I had a set from an IH on mine but I don't remember the model. I also had a different set I bought on an auction that I painted and put on but I have no Idea what they came off of. I have a post farther down about them. I am trying to sell them. Hope this helps.
Steve
Sid
09-20-2002 21:04:18
 Re: Re: Combine wheels on WD? in reply to Steve, 09-20-2002 20:48:12
Some of the guys around here use Gleaner wheels
