POWER STEERING PROBLEMS- NEED HELP!!!!!!!
AC D14 Man
09-18-2002 13:44:48
hey guys-
We have an AC D-14 that we use to mow lawn. The steering has been so good on it for a long time then problems began. The steering begins to stick and will not turn smoothly almost like no PS at all. Yet, sometimes it will turn smooth one way and will not the other way. I have no idea what it could be but I hope you guys can give me some help! Thanks!!
steve
09-18-2002 19:40:19
 Re: POWER STEERING PROBLEMS- NEED HELP!!!!!!! in reply to AC D14 Man, 09-18-2002 13:44:48
since it is erratic, there is a good chance that it is dirt or contamination floating around in the system. easy "fix" is to drain and change the oil. lot of times this helps, sure cant hurt. there is always the chance that a spool or vavle is sticking and needs removed and cleaned, but maybe the new oil do it since it is not "always bad".
