Mystery spring on B
Bus Driver
09-18-2002 10:08:55
Model B Serial# B113509. The "carburetor link" from the governor to the carburetor has spring part #212321 hooked in a hole in the link and attached to the manifold assembly. That is the only spring shown in the parts catalog associated with this link. This tractor appears to have only the original paint and there is a another spring with paint on it-appears to be original. This spring clips around the rod (link) nearer the carburetor and the other end of the spring hooks into a hole in the back of the generator bracket. The spring is longer and larger than #212321. The mystery spring is broken and I (think I) need a replacement. Can you shed light on the mystery?
ken little
09-18-2002 11:21:43
 Re: Mystery spring on B in reply to Bus Driver, 09-18-2002 10:08:55
