HELP I.D. ALLIS TRACTOR
James
09-15-2002 14:59:35
I just got an Allis Chalmbers tractor I'm trying to identify. Casting ahead of seat is u25-12. This is a tricycle tractor with rubber tires. All the pictures I find of U tractors are wide front. Unstyled tractor. Pedals are under the rearend housing. Hand brakes . Belly mounted sicklebar with lift mechanism between belt pulley area[no belt pulley] and rear axle housing.
Greg Ballantyne
09-16-2002 17:25:16
 Re: HELP I.D. ALLIS TRACTOR in reply to James, 09-15-2002 14:59:35
That UC is a good find, at least around here (Md.) I don't see them much. There are a nice looking tractor, I always wanted one.
Frank
09-15-2002 15:32:41
It sounds like you have a "UC",does it have an overhead valve engine or a flat head?
James Deemer
09-15-2002 20:07:03
 Re: Re: HELP I.D. ALLIS TRACTOR in reply to Frank, 09-15-2002 15:32:41
Thanks you for your reply Frank.
It is an overhead valve engine.
Bryan Smith
09-16-2002 07:06:52
 Re: Re: Re: HELP I.D. ALLIS TRACTOR in reply to James Deemer, 09-15-2002 20:07:03
Frank's probably right. If it's not a UC the only other thing that comes to mind is an unstyled WC.
Frank
09-16-2002 17:31:08
 Re: Re: Re: Re: HELP I.D. ALLIS TRACTOR in reply to Bryan Smith, 09-16-2002 07:06:52
That casting # ahead of the seat is the same as my "UC".
