Re: WD45 Drains and Fill sites?
Dave Grubb
09-09-2002 09:03:43
It has happened that when you remove the drain plug for the hydraulic sump nothing comes out. The problem is that the drain hole is sealed over by caked sludge. Use a wire or something and open it up. You should try to use a bent wire and scrape as much sludge from the sump as you can. Also clean the drain plugs real good. The hydraulic ones have a magnet in them and the others could have had magnetic plugs installed. I use FS brand Power Fluid in my hydraulic system and 85w140 gear oil in the transmission, rear end and final drives. By the way the final drives have no drain plugs, you either use a suction gun to remove the old lube or just top off the drives.
