Loader question
D19
Errin OH
09-09-2002 06:43:17
I am sure it has done before, but looking over the tractor I have some concerns about putting a loader on it. The loader frame will be mounted to the rear axel, extending up to the front mounted to the side rails. The front (wide) axel is held in place with two pins. One on the axel itself and one under the engine on an A frame coming from the axel. Are these adaquite for the added weight or would I need to beef up or upgrade it some how?
MONSTER MARK
09-10-2002 20:25:00
 Re: Loader question - D19 in reply to Errin OH, 09-09-2002 06:43:17
I am using a Westendorf TA26 loader on my D19. The Westendorf is a quick attach and does not have tower rails to the rear axle as do the AC loadrs. The front is heavy enough to support the loader. On mine, the front pin did not go into the hole far enough. I welded a 1/2" thick pad to the carriage and then rewelded the pin farther out for a better fit. Another fellow did the same thing with a D17. Neither one of us has had trouble since. Hope this helps.
david l wilson
09-12-2002 00:54:48
 Re: Re: Loader question - D19 in reply to MONSTER MARK, 09-10-2002 20:25:00
i have a schwartz loader on mine and it mounts like yours , i have put some preaty good loads on it without any problems. i use mine almost daily and feed big bales [15 to 1800 lb on frozen and rutted ground all winter. i would not worry about it if i were you . hope this helps. david l wilson
