Speed up?
Ricky Mork
09-08-2002 11:31:08
Was mowing and tractor seemed to speed way up now cannot adjust idle down low ? Governor Problem?
Is governor major to work on? What to look for ? Governor rod seem tto move when you run throttle up then down.
Thanks Ricky
david l wilson
09-12-2002 01:01:08
 Re: Speed up? in reply to Ricky Mork , 09-08-2002 11:31:08
sounds like gov. weights to me. check in a repair manual but not too dificult to do . if it is the gov. weights make sure to get all the pieces out of the front engine cover and oil pan or you will have big trouble. if you need any more help let me know .david l wilson [email protected] . good luck
