D15 screeming clutch
Randy Williams
09-07-2002 10:42:09
I have a D15 that when i let off the clutch it starts a loud screeming. It dosen't matter whether its in gear or not, but when it's not in gear, it starts jerking like it's trying to engage. The noise stops with the clutch in. All the noise is in the rear axle area. Is this a bearing or worse?
JMS/MN
09-08-2002 19:41:34
 Re: D15 screeming clutch in reply to Randy Williams, 09-07-2002 10:42:09
First guess is the throwout bearing. If the noise stops with the clutch pushed in, it can't come from the rear end, because nothing back there is turning. Isn't there a pop off cover under the clutch housing? check for metal filings, etc. there.
Zonie
09-08-2002 10:28:07
Sounds to me from your discription that you have a bearing going out in the transmission. I belive if it was the throw out bearing it would not jerk when in neutral. I'd find out what the problem is and get it fixed, running it like this will cause serious damage!
Gordon-(TN)
09-07-2002 10:54:13
Sounds like the throwout bearing to me. hope this helps
Gordon_(TN)
Gordon-(TN)
09-07-2002 10:54:01
Gordon_(TN)
