D-14 Allis Chalmers
ERIC CHAMPAGNE
09-06-2002 06:15:32
I have a d-14 with a 3pt hitch I am having problems with the hyd. oil pumping over into the rear axle oil resevoir. Anyone having experience with this can you inform which is my next move. THANKS IN ADVANCE
Scott (MO)
09-08-2002 20:23:22
 Re: D-14 Allis Chalmers in reply to ERIC CHAMPAGNE, 09-06-2002 06:15:32
Eric, Bryan is correct on the problem your having. Anytime the ram cylinder leaks or the hydraulic hose going from the control valve to the ram cylinder leaks , it fills up the rockshaft housing and leaks over into the axle housing. It's been a while since I have been in a D14 , but if I remember right the only thing you need to split or take off the tractor is the rockshaft housing (lift arm housing )on the very back of the tractor. This isn't a big deal (If I remember?).Once it is off , the cylinder and the hose is accesible. Hope this helps. Like I said it's been a few years since I had to do one , so if I'm wrong , maybe one of these other AC guys could help you.
Scott
Bryan Smith
09-06-2002 06:37:12
There's a hose that goes from the hydraulic valve through the inside of the tractor to the 3 point hitch cylinder (also located inside the tractor on a D series). Your hose has probably sprung a leak, allowing hydraulic fluid to leak into the rear end area (my D15 does that a little but not enough to repair yet).
I've never done this repair, but I would guess you have to split the tractor to get to it. Lots of time and labor for a little hose. Had one fellow on this list say that now that he's done it once he feels he could do it again - with parts on hand - in one day.
