Seal -B steering
David Maddux
09-04-2002 04:58:43
I am having trouble finding the seal I need on my steering shaft. It is a Ross steering box The seal seems to be made of cork with a washer over it. This is for a model 46 B Allis. E-mail or call me at 816-918-3840 or 816-320-3282.
David Maddux
09-04-2002 14:12:30
 Re: seal -B steering in reply to David Maddux, 09-04-2002 04:58:43
Well, I think I have found a solution for my seal problem. For the others that might be interested,I found a new style seal that fits tight on the shaft but a little loose in the casting. I put the shaft in the unit fit the seal over the shaft and set set the seal in with J-B weld, then verily easily pulled the shaft out. Not much movement going on there or heat so I think it will work. The seal is a Federal Mogul #252277 wish me luck, just need to stop the grease leak.
