Need some info.on allis chamler tractor
harry
09-03-2002 19:46:56
I need to find out what i have? These are some numbers wd 354514 pa,24d,u3019. I would like any info please . thank you
Brian G. NY
09-04-2002 06:28:14
 Re: need some info.on allis chamler tractor in reply to harry, 09-03-2002 19:46:56
That's the "engine" serial number. If the engine is original, it is most likely a late 1953 WD; just before the WD was superceded by the WD-45. To get the actual year of manufacture, you will need the "tractor" serial number which is located on the LH rear vertical surface of the differential/brake housing. Look for a smooth "boss" between the brake spring hole and the brake adjusting bolt/locknut with the number stamped on it. The numbers are not stamped deep so you may have to do a little scraping to find it.
Bryan Smith
09-04-2002 08:33:43
 Re: Re: need some info.on allis chamler tractor in reply to Brian G. NY, 09-04-2002 06:28:14
Here's a web site I put up with images of serial number locations - there's one there for the WD and WD45 that may help you. Scroll down until you see "tractor serial number images" on the right side.
