D17 Hydraulics
Donald Holden
09-03-2002 18:42:07
My neighbor purchased an older AC disc with a hydraulic ram that will raise/lower the wheel for field and road travel. The ram is equipped with hydraulic hoses to both ends of the ram. My D17 has only 1 hydraulic connect/disconnect under the seat. We want to use the disc for fall ground work and my question is this: Can I use the hydraulic ram and connect only the one end of the ram to the tractor's system for raising the wheel and then allow the weight of the disc to push the oil back into the reservoir when I dump the system? I am not familiar with the Tractors hydraulic system except the fact that it is high pressure/low volume piston pump that was original equipment on the Series ll tractor. My serial number is D17-33383. My neighbor has a Ford 3600 diesel that is not equipped with external hydraulic connection so I will do the heavy work with my tractor. His probably wouldn't handle it anyway!!
Thanks for your reply! I appreciate your help a lot!
Don and neighbor Tim
Diesel Don
09-03-2002 19:59:50
 Re: D17 Hydraulics in reply to Donald Holden, 09-03-2002 18:42:07
You can do that,just remove the hose from the opposite side of the cylinder and install a breather/filter in the port.
Don Holden
09-03-2002 21:09:12
 Re: Re: D17 Hydraulics in reply to Diesel Don, 09-03-2002 19:59:50
Thanks Diesel Don! I appreciate the prompt reply and I will be off to Farm & Barn in the AM to get the breather!
Don
Duey (IA)
09-04-2002 06:40:15
 Re: Re: Re: D17 Hydraulics in reply to Don Holden, 09-03-2002 21:09:12
Don,
The D17 will have high pressure hydraulics and if this is a low pressure cylinder, you may blow out the end or the seal at least. Cylinder should be able to handle at least 3500# working pressure. Duey
Don Holden
09-04-2002 14:58:08
 Re: Re: Re: Re: D17 Hydraulics in reply to Duey (IA), 09-04-2002 06:40:15
Duey, Are hydraulic rams stamped with the maximum pressure to be used? If not, is there another way to determine what internal hydraulic pressure a ram is rated for? I don't want anyone getting hurt because a hydraulic ram/hose burst under a load!
Thanks
Don
Duey (IA)
09-04-2002 17:28:23
 Re: Re: Re: Re: Re: D17 Hydraulics in reply to Don Holden, 09-04-2002 14:58:08
Don,
I don't think any of the old cylinders were marked. The high pressure cylinders and hoses tend to be smaller than low pressure. As you know, the pressure is per square inch and the more square inches the greater the lifting power and also there is greater pressure inside the hose and cylinder. Usually the high pressure hose is 3/8" and has two steel braids. The cylinder is smaller diameter with the same length stroke. Other than that, I really don't know what to tell you??? Duey
Don Holden
09-04-2002 21:06:54
 Re: Re: Re: Re: Re: Re: D17 Hydraulics in reply to Duey (IA), 09-04-2002 17:28:23
Thanks Duey! I will be careful. The hose appears to be high pressure, but the ram doesn't have the high pressure appearance that you would expect to find. It looks like it might have come out of Farm & Fleet as opposed to the Agco/Allis inventory.
Don
Bryan Smith
09-05-2002 13:24:32
 Re: Re: Re: Re: Re: Re: Re: D17 Hydraulics in reply to Don Holden, 09-04-2002 21:06:54
The YT site sells a conversion for D series AC tractors for a two-hose system if you want to go that route. Around $220 or so, but it does include a pressure reducer I think. Check it out - sounds interesting and would allow you to use a number of things with no modification.
Don Holden
09-06-2002 10:20:28
 Re: Re: Re: Re: Re: Re: Re: Re: D17 Hydraulics in reply to Bryan Smith, 09-05-2002 13:24:32
Bryan, sounds like the price is right! I will check it out and I am very thankful to you and all of the other good folks who responded to the question.
Don
Daren
09-08-2002 19:01:59
 Re: Re: Re: Re: Re: Re: Re: Re: Re: D17 Hydraulics in reply to Don Holden, 09-06-2002 10:20:28
The larger cylinders that I have, have 4 long bolts on the sides. Also the ram is larger in size. I use both 2.5 and 3 inch on my series3.The idea with taking off the hose and putting on a breather cap works great, the wheels won't come off the ground but the pressure on them will be off. A little weight on the disk and in the ground it will go.
