WD45 Still won't start
Keith A
08-30-2002 23:18:51
I have a WD45 that suddenly one day quit running, I have not been able to get it to start for 2 months ! Things tried so far: New Points, New Coil (12 volt), new rotor and cap. It just does not seem to want to fire. Ignition is hot from switch to coil and from coil to distributor. Any Suggestions would be appreciated. Thanks in Advance.
Tom
08-31-2002 19:38:48
 Re: WD45 Still won't start in reply to Keith A, 08-30-2002 23:18:51
Do you have a good spark at the plugs? Are you sure it is getting gas?
Keith A
09-01-2002 22:38:46
 Re: Re: WD45 Still won't start in reply to Tom, 08-31-2002 19:38:48
Yes, It's getting "plenty of gas".
Duey (IA)
08-31-2002 06:17:34
Keith,
Remove the dist cap, rotor and dust plate. Bump engine over untill the points are closed. With the ignition on, very carefully, with a screw driver, open the points. There should be a spark between the contacts. If there is no spark, the contacts are dirty or have an oily fingerprint on them or possibly the condensor is bad since you didn't say you replaced it. Take a piece of hard paper (like a matchbook cover), insert it between the contacts and drag it out. This will sometimes remove the contaminant. Duey
Keith A
08-31-2002 13:17:35
 Re: Re: WD45 Still won't start in reply to Duey (IA), 08-31-2002 06:17:34
Thanks Duey, I'll give that a try. Kind of frustrating, I learned from my Ag Shop Teacher 28 years ago that only three things make or break a gasoline engine starting. 1)Fuel 2)Ignition 3)Cranking system. By the way I did replace Condenser (it came with kit). Keith
Brad
08-31-2002 20:27:48
 Re: Re: Re: WD45 Still won't start in reply to Keith A, 08-31-2002 13:17:35
Make sure you check ignition switch, if switch is in off position or shorted out it will ground out your ignition system.
