Final 'C' oil pressure update
Ron from IL
08-29-2002 08:15:53
Hey Guys,
On Tuesday, made the tube that goes up into the oil filter from copper (couldn't find any 1/4" brass tubing). Filled the tip with 'Pig' epoxy putty and drilled the necessary 7/64" holes. Put everything back together, but couldn't get any oil pressure.
Last night, I took it all apart again, blew the lines clear w/compressed air, and re-assembled. Lo and behold, OIL PRESSURE!! For the first time since I've owned the tractor! But now, I've got an oil leak from the area around the oil pressure gauge (it cracked a few years ago, and was repaired w/JB Weld). Repaired it with some more 'Pig' putty. Will re-assemble tonight.
Thanks for all the help!
Ron
