AC-CA, Need info for starter / Serial Number
DinMI
08-28-2002 11:12:07
I have what I think is an Allis Chalmers CA, but unsure of year, etc. Starter that came with tractor has never worked correctly, bought it used. I have numbers AM-3787-5 that came off from the panel between the tire and the seat. Anyone know what these numbers are? A friend is wanting to rebuild my starter(again)but I need to order correct gear assembly.
Thanks
Tony
08-28-2002 12:19:14
 Re: AC-CA, Need info for starter / Serial Number in reply to DinMI, 08-28-2002 11:12:07
Serial no is to left of shift lever. CA######## The nunber you have is casting number. Your starter should have a delco number of 1107096 if my book is right. Tony
DinMi
08-29-2002 04:36:05
 Re: Re: AC-CA, Need info for starter / Serial Number in reply to Tony , 08-28-2002 12:19:14
Thanks.
I take it my serial number is CA7389 then, so I have a 1951. I appreciate the help, new to this and learning as I go.
