Hydraulic control valve on D17 Diesel
Jeff Long
08-27-2002 21:11:05
I have a 1959 series 1 d17 diesel with a 3 lever control valve mounted on fender. Is this factory equipment or did someone add it. It has two hoses going to rear for equipment. Tractor does not have 3-point but I plan on adding one. Will I need different valve or is this sufficient. Also where can I get replacent valve if this one is inoperable. Tractor has been setting a few years but was running when they quit using it. Any help would be appreciated. Thanks
Denny
08-28-2002 08:45:50
 Re: Hydraulic control valve on D17 Diesel in reply to Jeff Long, 08-27-2002 21:11:05
I have a 1960 D17 diesel. It did not come with the valve that you describe. Sometimes these were added when they put a loader on the tractor. Sometimes they added a front mounted pump at the same time so that there would be full time hydraulics. Where are the hydraulic lines hooked to the tractor? It would help enormously if I could see pictures of where these hoses connect to the pump (or tractor body).
If you are adding a 3 point conversion, these valves will not be used at all. The cylinder for the lift arms is inside the transmission case. Lift for these arms is controlled by the bottom lever on the steering column. The top lever is for the traction booster.
If your main interest is a three point, these valves may prove to be useless - but they are useful. If you don't need them and want to remove them because they don't look nice or are in the way, you can sell them easily. I've been thinking of converting my trip bucket loader to full hydraulics and would need a valve (and hoses) like this to do that.
I can help you with pictures of a 3 point for the D17. I put a category I on mine for use with a bush hog and a scraper blade. The design I did cost about $80 and you can do it yourself with a little welding. It is also removable and doesn't require any welding to the tractor - it bolts on. I removed it recently and put it on my D-14 (fit without adjustment).
I'd like to hear from you. Your email address didn't work for me.
Jeff Long
09-09-2002 23:57:36
 Re: Re: Hydraulic control valve on D17 Diesel in reply to Denny, 08-28-2002 08:45:50
Denny, Got my manual finally. You were right. The control valve was a option for using lift cylinders on other attachment or a loader. Have to find someone to rebuild it or buy new one. Hey, try to e-mail those pictures of your three point hitch. Could sure use them. Thanks.
Eldon (WA)
08-28-2002 11:59:21
Denny.....I am going to make a 3 pt for my D17 and would appreciate any pictures you could email me. Thanks!
Eldon (WA)
08-28-2002 11:57:16
