Well, here we go again. I used my son's mower to do the mowing. We've practically no rain all summer and wouldn't you know when we get some heavy rains for a couple of weeks, the AC mower goes kapute. Oh well, I still love this machine. Well, I did everything you said Huey, (I think) and I am getting fire at the plugs. I put the mag on the vise and turned the lug as you said. Great fire at the points. They are set at .020. I even cleaned them. Then I checked for the alignment marks on the two gears. Well, I think I got them right, the steel gear has a pall opening. Is this the right mark? It's the only one I can find. On the fiber gear, the only mark that looks like a "C" mark is in the center, and looks like a snap ring with the opening being the mark area. I lined that one straight down and the steel one straight up. Then you mentioned that I "Tip-turn the engine backwards" to get the steel gear tooth straight up. I don't know what you mean when you say "Tip-turn the engine backwards". I took the steel gear and turned it so it was up and turned the fiber gear down and then connected the unit together with the 4 screws. Also I know that the firing order is 1-2-4-3. I think I am lining the wires correctly, they are in that order. As I am in the seat, facing the magneto cover, there is a hump on the cover that houses a brass rod inside the mag. I believe that the #l contact is to the left of that hump and #2 is to the right of the hump as I sit in the seat. Is that right? Also, when the tractor wouldn't start after I put everything back together according to your note, I removed the complete mag unit, then turned the lug unit on the back of the mag 180 degrees and tried it again. Still no luck. I wish I knew more about this mag, but I don't so I reach out to you who apparently do. Thanks for any assistance. P.S. The grass is probably good for another week now. Also, there is a big antique tractor show this coming weekend around here, so anyone who knows anything about these old tractors are working their own, so it is impossible to get them.
