Hydraulic Leaks Fix or Not
Rick
02-23-1999 11:00:34
My old Allis Chalmers 170 and my Massey 135 both have a build up of oil and dirt from hydraulic leaks over the years . Should I go to the trouble of replacing seals? Does it hurt the tractor to leaks some?
Craig
02-23-1999 16:23:18
 Re: Hydraulic Leaks Fix or Not in reply to Rick, 02-23-1999 11:00:34
Hydraulic oil doesn't hurt tractor unless it is a fire hazard. The problem you are experiencing is all to common to older tractors. The orings and seals have become hard and brittle over the years and start to leak. The choice to fix them is half and half depending on how much you want to spend.
