Re: Allis seized engine removal
Tom
08-25-2002 17:40:08
You did remove the sheetmetal plate/cover on the lower front of the bellhousing?
Ron Beauchene
08-25-2002 18:35:04
 Re: Re: Allis seized engine removal in reply to Tom, 08-25-2002 17:40:08
Exactly! I finally found the bolt heads through all the grease and grime and some light helps too. Had to knock the front counter-weight ahead to get clearance, but it's out now and onto removing the crank to see if the pistons will go out the bottom. Thanks to all those who responded.
