Wd-45 ??
Irv
08-25-2002 16:55:11
I showed a fella the wd-45 I just got the other day. He looked at the engine and said he thought it should have a cover the right side of the motor if its a 45, but he wasn't sure. Serial numbers to 1956 and engine casting no.is AM 3853-10. Is he right?
Thanks
Irv
Tom
08-25-2002 17:36:55
 Re: wd-45 ?? in reply to Irv , 08-25-2002 16:55:11
45s didn't have the cover on the right side, WDs and WCs were the ones. A 45 will have an oil line running to the governor too. And in the engine serial no. it will say 45 somewhere I think. Sometimes the nos. are fainter than the actual serial no. You may have to scrape paint to see.
Irv
08-26-2002 05:46:23
 Re: Re: wd-45 ?? in reply to Tom, 08-25-2002 17:36:55
I'm glad its the right one. I didn't know the engine was serial no'd, too. Where do I look for that?
Thanks, Irv
Brian G. NY
08-26-2002 06:08:21
 Re: Re: Re: wd-45 ?? in reply to Irv, 08-26-2002 05:46:23
Irv, Tom is right, the WD-45 "engine" serial number is prefixed by "45". See my reply to wdwilson above for more info. BTW, the engine serial number is located on a flat surface on the side of the block near the intake throat of the carburetor.
Irv (Ia)
08-26-2002 19:41:20
 Re: Re: Re: Re: wd-45 ?? in reply to Brian G. NY, 08-26-2002 06:08:21
Sure enough, its a 45. I found the no., 45-71731-G
Thanks to all for the help. It makes things a lot easier.
Irv
