Mower
Peter
08-24-2002 22:19:31
I have a 1950 WD, it came with a mower that is mounted on the right side and driven from the rear via a drive shaft under the tractor.It can be removed by loosening two bolts under the tractor and tilting it out of its'saddles'.It is of AC manufacture and has "twin wheel drive" marked on it. Does anyone know the model of this mower? I would like to find an operators manual for it if they are available. It appears to have seen little service and works very well but it would be nice to know about its proper set up and maint to keep it in good shape. I am quite sure it was improperly set up when I got it as the changes I have made have improved its performance. Thanks Peter
JMS/MN
08-25-2002 15:28:20
 Re: mower in reply to Peter, 08-24-2002 22:19:31
Sounds like a Model 80S (for side mount) to me. Also came in the 80R rear version, and I believe a pull type. Twin wheel drive allowed operating the mower at most any angle from 45degrees below horizontal, to vertical. No pitman allowed that.Twin wheel drive was a belt driven assembly mounted right on the mower bar. Had one 30 years ago on the D17- keep the unit well greased, watch for wear on the cast bar connecting the two wheels to the sickle. The bar breaks when slop develops in the attachment to the sickle. Break can be welded, but it's a tricky job, and needs to be done extra thick to gain strength.
Brian G. NY
08-26-2002 06:21:04
 Re: Re: mower in reply to JMS/MN, 08-25-2002 15:28:20
It could be an 82S, (the improved version of the 80S) which has a much heavier cut bar and heavier "cage" around the gear box. One of the biggest improvements and the easiest way to tell if it's an "82" is the use of ball bearings on the main pivot points at each end of the gear box. The "80" had no bearings and was prone to premature wearing. The heavier cut bar on the "82" is also much less prone to developing a permanent "arch" that the "80" was known for.
JMS/MN
08-26-2002 16:43:45
 Re: Re: Re: mower in reply to Brian G. NY, 08-26-2002 06:21:04
Always wondered what the difference was between the two- must be "product improvement". Thanks for the info. I'll bet I had the older one.
Brian G. NY
08-27-2002 06:23:23
 Re: Re: Re: Re: mower in reply to JMS/MN, 08-26-2002 16:43:45
To A-C's credit, in most cases they did make changes when a problem became evident after the machine was put to the real test out on the farm. For example, the later WD-45s had 3-plate hand clutches; apparently the extra "oomph" of the new engine caused premature wear on the old 2-plate clutch. The later WD-45s also had a stronger 4 bolt pivot plate on the WFE which replaced the earlier 3 bolt plate.
Peter
08-28-2002 19:29:46
 Re: Re: Re: Re: Re: mower in reply to Brian G. NY, 08-27-2002 06:23:23
Thanks for the info, I will check tommorrow and see if it has the ball bearings. It is a very substantial unit, I have an old ferguson mower with a much lighter bar than this has. I am slow to answer as we have been using the WD and this mower to cut hay. The old tractor handles an International 47 baler very nicely, the hand clutch is a neat feature. Peter
