D-17 valves stuck
Lee
08-24-2002 09:27:10
I am working on my brother's D-17 gas that had 3 valves stuck. I was able to get 2 of them free with oil and tapping with brass hammer. The other valve is stuck in the open position. Does anyone have any suggestions other than pulling off the head. Thanks
steve
08-24-2002 16:05:23
 Re: D-17 valves stuck in reply to Lee, 08-24-2002 09:27:10
i think i gave the guy above you some good info for the wrong question. i would soak the stem with WD40- then try to twist it with vice grips, and tap with hammer.
Greg Bahr
08-24-2002 17:39:12
 Re: Re: D-17 valves stuck in reply to steve, 08-24-2002 16:05:23
If the WD-40 don't work try KROIL you should be able to get it at any auto parts store. Another good rust buster is called P-B Blaster good luck Greg
